How to configure multiple 24-bit ASIO Dests?
Garry
Post by Garry »
I'm just getting back into trying to use my Pulsar 1 card, so I'm an old newbie. I have a project setup just fine using 24-bit WAV (10 pairs). Now I want to try the same thing with ASIO and SONAR. Every time I try to add a second ASIO 24-bit Dest, it complains that I have one already. Is there an ASIO control panel somewhere that I need to configure the number of ASIO drivers (similar to setting the number of WAV drivers)?
Thanks!
First, load ASIO Source and Dest into the project. Then double-click the ASIO Source to set amount of I/O.
or right click on the asio source module....
check the manual, it's on the cwa site.
Garry
Post by Garry »
I figured out that double-clicking lets me see the number of ASIO channels, but it won't let me edit the value. Now what? I think I'm close... I've been churning through the manual, but haven't found this covered anywhere (yet).
Garry
Post by Garry »
Got it. Need to use PageUp/PageDn. What a weird user interface... Thanks for the prompt replies.
<font size=-1>[ This Message was edited by: Garry on 2004-11-17 19:48 ]</font>
you surely can edit those values. either click, hold and drag that number to one you like.
*edit* oops left off the "or", as in, "or click and type".. :oops:
<font size=-1>[ This Message was edited by: garyb on 2004-11-17 21:48 ]</font>
blazesboylan
Post by blazesboylan »
Click + type works for me.
