PC Won't Suspend
Garry
Post by Garry »
Since installing my very old Pulsar into my very new PC, I get a message that the "Creamware Pulsar" driver is preventing the system from going into suspend mode (when left unattended for a few hours). Is this typical/expected behavior? Is there a setting somewhere to make the Pulsar play nicer with my system?
daws don't need suspend.
Guest
Post by Guest »
pulsar runs in the backgruond and won't allow suspension. You can disable the creamware from loading up .But suspension on HD ? why?
This is also the reason why CW drivers aren't 'signed': they don't comply with the powersaving stuff. You cannot expect DSP's to reload their OS when a computer resumes from standby, or to keep it in memory...
If you close SFP or it's icon, it should be fine to suspend and resume though.
Garry
Post by Garry »
Thanks for the replies. I just noticed the message after leaving the PC on a couple times (overnight, off to work) and thought I'd ask.
