Final Liza
ThomasT
Post by ThomasT »
Hallo!
I asked for samo multibands comps and there are some. Great.
The dadev-plug ins are not bad but too DSP hungry!
But Final Liza is really great!
My wishes:
1. A four band version
2. A two band version (less DSP when you need only two bands)
3. A one band version (dito)
With a one-band version I don't mean a full range compressor. I mean a compressor that works only in a given band. E.g. from 150-350Hz to control the low mids of guitars.
Two crossovers and a fullrange comp. would't work so good. Because the comps have a litte but phasing effects causing deleys.
Generally to all device-developer:
Please take attention to the dsp power!
Every litte percent can decide if it can be used in the project or not.
If you feel you need more dsp power to get a little bit better sound make it switchable.
Sometimes you can live with a litte bit worser sound.
Not exactly what you're asking for, but still, check out alfonso's X-over insert!
ThomasT
Post by ThomasT »
I know this. I'm sure I have this plug-in.
But a compressor has a herable delay.
So the other band has to be delayed.
But: how much?
The flanger in the example shall work, because it produces comp filtering naturally.
But insering one Vinco and nothing in the other slot should produce hearble comp filtering near the crossover-frequency.
But - maybe - worth a try.
