Some neat features:
-16x16 synthi-style mod matrix with the original routings
-Trapezoid Generator or Manual (midi) Enveloping of the VCA
-Joystick, Reverb, Meter as found in the original
-A few presets to demonstrate routing apps
-MDL panel for quick modifications
Thanks j9k for two of the most important elements in the Synthi: the mod matrix and the trapezoid generator.
Please note that the Trapezoid lfo needs to be started when you load the patch-- click the left "off" button on the right side of the module.
This patch requires:
1) FleXor
2) The SpaceF Text Module
http://www.modularsynth.co.uk/downloads ... ularv3.zip
3) J9K's Matrix and Trapezoid Modules:
http://www.planetz.com/forums/viewtopic ... forum=15&3
http://www.planetz.com/forums/viewtopic ... forum=15&1
Also be aware that it's a bit DSP-hungry-- not sure if it'll run on a 3-dsp card.
New versions will probably pop up as I play with it more.
<font size=-1>[ This Message was edited by: doof on 2005-01-23 14:07 ]</font>
Now in Zip format
<font size=-1>[ This Message was edited by: doof on 2005-01-23 14:37 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/mod ... ynthiA.jpg" BORDER="0">
