Asus P4P800 SE Hard drive
Music Manic
Post by Music Manic »
Thanks for cpu recommendation guys.
Have just bought with RAM.
Could you suggest which hard drive to go for.
Does SATA work well?
AndreD
Post by AndreD »
stay with ata! (no s-ata)
http://product.samsung.com/cgi-bin/nabc ... id=SP1213N
Best,
Andre
Stubbe
Post by Stubbe »
Could you elaborate a little on the no s-ata policy (I for one are curious since I am running S-ATA, so far OK, but who knows...)
Cheers
Stubbe
Music Manic
Just read that SATA may interfere with other hardware,but don't take my word for that.
patricka6
Post by patricka6 »
I would guess that enabling the SATA controller uses up another IRQ therefore possibly causing IRQ sharing conflicts. Other than that SATA (Raided "0")is supposed to give better performance. From what I've heard and read.
braincell
Post by braincell »
The problem is that there are only 15 possible IRQ numbers and now motherboards use so many of them on built in things. You have to disable the ones you don't need. Most modern PCI cards are able to use the same IRQ as other divices but Creamware cards are different. This is a bad thing about Creamware.
it is as good or bad as with any other card and in noway CWA related.
If a mouse interupt isn't handled in time you won't even notice, if a harddisk is a ms late this is buffered, but a real-time audio stream MUST be serverd when it's due - otherwise you'll hear it :wink:
cheers, tom
braincell
Post by braincell »
Other pro audio cards don't have the irq problems that creamware cards do.
i doon't think that's true at all. most other cards won't have multiple cards running either.
