MIDI recording in Cubase SX
deejaysly
Post by deejaysly »
I can't seem to record MIDI notes in Cubase SX when i have the MIDI track input connected to 'Creamware MIDI In/Out'... but it works okay when i connect to 'Creamware MIDI In/Out [Emulated]'
Does anybody know if this is normal behaviour? or do i have a real problem?
TIA
8-Bit
Post by 8-Bit »
you mean PULSAR MIDI A (IN) is connected to your SEQUENCER MIDI Destination, correct?
That is what you want. Thats how mine is setup, and it works dreamy.
Also, have your sequencer MIDI Source connected to your PULSAR MIDI A (out).
(this is all bearing in mind that you use your pulsar midi i/o and not some other devices)
Cheers,
8
/**/ 8-Bit /**/
Liquid Mathematics
most likely you need to enable the regular (non emulated) drivers in the vst multitrack manager's midi menu. don't use the emulated ports, they make problems(well, if they don't then ignore me, i guess...)... of course, you did this right?
http://pinnacle.custhelp.com/cgi-bin/pi ... ZT0x&p_li=
<font size=-1>[ This Message was edited by: garyb on 2005-02-15 05:38 ]</font>
