Free multitrack recorder
nprime
Post by nprime »
http://audacity.sourceforge.net/download/windows
Maybe everyone already knows about this program, but here it is again for any newer members.
R
after I installed this app and it stopped playing in the middle of a file my 'wave source 1' is gone.
Uninstalled it, re-installed scope drivers etc - no cure. Wave source one doesn't do anything anymore, in whatever app. Wave source 2 is OK - I'm running Win2K server.
nprime
Post by nprime »
That sucks!
I hadn't loaded it in any machine with creamware hardware, just my internet computer.
Maybe everyone should stay away from this.
Sorry, wouldn't have posted it if I had known there were any problems.
R
<font size=-1>[ This Message was edited by: nprime on 2005-02-17 20:27 ]</font>
samplaire
Post by samplaire »
I'll give it a try on my son's computer. He wants to do some multitrack recording (singing along with a song) and he's just 9 so the app will probably be very good for him. But to avoid frustration I have to try it first. I wanted to install Logic Fun in the machine but it doesn't support XP!
darkrezin
Post by darkrezin »
This might be a long shot but if Logic Fun works like normal Logic, this should work:
Install Logic Fun on a machine on which it will install. Now, copy the folder which you installed it to, to the machine which you can't install it on. There may also be a Logic preferences file in the C:Windows folder which you can copy over.
I have no idea how protection works on Logic Fun, but it's worth a try :smile:
edit: this is assuming it's only the installer which you can't run in XP - this was the case with Logic versions before 4.8 if I remember correctly. However, it was still technically possible to run it on Windows2000 (XP wasn't around at the time, or was just released. 2000 is essentially the same as XP)
<font size=-1>[ This Message was edited by: dArKr3zIn on 2005-02-17 22:08 ]</font>
samplaire
Post by samplaire »
Good tip, thanks! I'll try it obviously :smile:
remember this?
http://www.rme-audio.de/english/faq/10entrye.htm
thanks, GaryB :smile:
I knew about the #10 limit, but not about all the details.
Got Wave1 back after kicking out all obscure wav stuff from the registry and copying a .mdl from another installation - dunno which cured it.
Zer
Post by Zer »
or try
Ntrax
http://www.fasoft.com/what_is.shtm
Not for free but cheap.
Prehaps you might want to add
http://www.quaderno.com/
for some issues.
<font size=-1>[ This Message was edited by: Zer on 2005-02-22 10:02 ]</font>
samplaire
Post by samplaire »
I tried it and it worked 50%. I mean, the app opens as expected (after moving it from win98 to xp) but it can't see any audio driver. There is a utility provided to setup audio but it doesn't help.
I'll try the N-track then.
Zer
Post by Zer »
samplaire
Post by samplaire »
Looks promising :smile: Thanks!
I ended with a bundle of programs from Acoustica for $70 :smile:
http://www.acoustica.com/products.htm
very simple and straight forward stuff, but well thought out, no gimmicks.
easy to switch (and convert) between Mp3, Ogg and Wav.
cheers, tom
BingoTheClowno
Post by BingoTheClowno »
You should try Graphedit that comes free with DXSDK (Microsoft's Direct X Software Dev Kit), it has a similar interface as SFP (virtual connection wires) but it allows for much greater control and setup of the filters involved. (Plus, you can add DX audio plugins, including NI's)
http://msmvps.com/chrisl/archive/2004/11/13/18992.aspx
Zer
Post by Zer »
as a multitracker for mastering?
Graphedit maybe a wonderful tool, when it comes to video editing and special routing things, I`d say...But you may post a screenshot here, so we all could benfit from how to use graphedit as a multitracker mastering machine?!
BingoTheClowno
http://www.illiminable.com/ogg/graphedit.html
No multitracking capabilities AFIK, just a quick conversion tool and what not.
