AES/ ADAT converter, Is there one?
Labman
Post by Labman »
I want to get the AES digital signals from my effects units directly in and out of my Powerpulsar and Pulsar2 via ADAT i suppose (or any other possible way). Does anyone know of a converter that can do that? I would only want to take up one lightpipe i.e. 8 channels in and 8 channels out.
Thanks in advance.
labman
there is certainly one, but a reasonably priced converter will only be opt sp/dif(2 track), not what you're looking for. you might actually be just as well off using an ad/da connected to adat, and analog io on your effects. there won't be any master/slave problems(i'll bet your effects only want to be sync master and in a digital connection, there can be only 1 master) and there's no assurance that the digital connection will truly sound better.
