instaling SFP on a new
sidon
Post by sidon »
I have a new PC : P4 1G samsung ram , 2 X 80G SATA drives ,
I have just installed the OS ,
My partions are :
20 for OS ,
60 general use ,
40 Audio softwares , cubase etc ,
40 general use ,
What I wanted to know is whre should I install my soundcard drivers ,
(creamware's Luna)
should I put together with the OS or should it be else wehre
Thank,
SId
Plato
Post by Plato »
yes, on the same partition as the OS.....it should automatically attempt to install there anyway....it'll create a directory called C:/Scope....just go with the flow!
:smile:
sidon
Post by sidon »
Thanks for answering,
But should'nt it be in the same dir as my audio apps , I.e cubase ,etc.
which I intent to install on my E drive
<font size=-1>[ This Message was edited by: sidon on 2005-03-11 17:00 ]</font>
Mr Arkadin
Post by Mr Arkadin »
Is your keyboard broken sidon - that last post is almost incomprehensible?
<font size=-1>[ This Message was edited by: Mr Arkadin on 2005-03-11 14:46 ]</font>
no, put all the apps on c:. put all your song data on the second drive.
sidon
Post by sidon »
Sorry for the last post ,
Mr Arkadin you are right ...
I fixed it
anyway ,
I was told that I should put my audio apps in a differnt hard drive , inorder to utilize the hyperthreading of the pentium .
what do you think about this?
<font size=-1>[ This Message was edited by: sidon on 2005-03-11 17:02 ]</font>
ht is bs. your computer will not do double the work just because it has 2 virtual processors. it MAY do slightly more mork if all the apps ivolved are properly optimized(unlikely).
you definitely want your audio DATA(tracks) on a different drive, however.
sidon
Post by sidon »
Hi startdust,
thanks for the info ,
What I see is only one cpu load window in the task manger,
but I have the HT enabled in the BIOS ,
and also I see 2 cpu in the device manger.
Is there something wrong?
Thanks,
Sid
<font size=-1>[ This Message was edited by: sidon on 2005-03-12 11:17 ]</font>
Open task manager, in the menu go to View>Cpu History and see if its set to One Graph, all Cpu's
sidon
Post by sidon »
Thnaks alot guys.
I would appreciate if someone can link me to a good articel about the way HT works.
I was thinking it should work with a differtn cpu per HD , but according to what ws written here , it might not be the case.
Ant wya thanks a lot for all the info
Sid
it most certainly does NOT work one cpu per drive. :grin:
sidon
Post by sidon »
thanks guy,
It seems to work now.
Sid
