YOU CAN DO IT ! ( since the FM possibility appears in some devices )
The Waldorf and the Creamware WavetableOsc with one or two FM inputs, in addition to the other parameters ... I wonder if there are other parameters that are non exploited or non documented in those 2 fat atoms.
Thanks in advance !
It's not cos the option appears in one device or module, that it can be added to these. If the module is closed and only has an async freq input, it doesn't make sense to force it to eat audio rate signals using some conversion module.
On the other hand, if it's open or someone can hack it like that, put me on the list
