monitoring fx
Jah Servant
Post by Jah Servant »
I can't seem to get to any fx out of the monitor outputs.
How is it done?
return the fx to a channel and then send that channel out the monitor, just like you would with a real mixer.
Music Manic
Post by Music Manic »
fx are routed to mix outs.
Jah Servant
ok then so what is the MnL&R effects returns for?
I thought that these route to the monitor outs and you'd just send the effects out to them as well as to your regular returns for the main mix, no?
you can do it that way...check the rtn page on the master channel strip. is the aux to mon mute enabled?
Jah Servant
I tried turning it off, by default it's on, but still the fx doesn't come through, that's what I don't understand.
beerbr
Post by beerbr »
Check out if there is input signal at your effect?? May be that you forget to turn the aux send enable.. (make it ON [light green] at the channel stripe of your track)
<font size=-1>[ This Message was edited by: beerbr on 2005-04-27 00:19 ]</font>
Jah Servant
that's not it, the meter's move on the mon fx return, so there is a signal there, it just doesn't go to the monitor outs for some reason.
plus the fx come out of the main mix, so they are definately on.
Shayne White
Post by Shayne White »
You could also check out my mixer, Route, which has a universal bus system. :smile:
http://www.planetz.com/forums/viewtopic ... forum=16&1
Shayne
Melodious Synth Radio
http://www.binary-sea.com
wayne
Post by wayne »
Bump.
I'd like this to work.
