midi problem (again)
soundstone8
Post by soundstone8 »
After playing my synths or sampler i often get a hanging note that will only stop when i reset midi devices in cubase. This happenes on both soft and hard instruments !
Its got me scratching my head to the point of serious hair loss please help !
<font size=-1>[ This Message was edited by: soundstone8 on 2005-05-01 17:40 ]</font>
sandrob
Post by sandrob »
wich master keyboard you use?
if you use roland, then disable midi clock.
that should solve your problem.
soundstone8
I use an evolution mk-149 , im not sure if it has this setting ! its just a bog standard no frills controller . would the clock settings in cubase make a difference ?
if the the powersupply of the keyboard is (or has become) too weak, that model behaves exactly as you write.
since wall-warts are crappy by nature just use another one (which you have probably laying around) - it's nothing special.
soundstone8
That will be it then ! the wall wart is two week i have swapt it for the correct one and all seems to be well,,,,, NICE ONE ! I would have never come up with that solution thanks
