Modular meets CubaseSX
roy thinnes
Post by roy thinnes »
<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .mp3"><img src="/forums/images/listen_icon.gif" border="0" alt=" Sound Example"> Sound Example</a><BR> <a name="planetz-tag"></a>Type: Synth<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar 3.x<BR> <a name="planetz-tag"></a>Requires: Modular 3<BR> _____________________________________<BR><BR> to all the CubaseSx users out there:
this is a patch which comes along with a DeviceManager panel.If you want to check it out, unpack the CWModularSxDevice.xml into the DeviceMaps folder of Cubase.Also some presets included (named with numbers).Happy tweaking!
<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/mod ... evice.jpeg" BORDER="0">
next to nothing
Post by next to nothing »
man, i have no idea what this is...
are you saying this xml file actually integrates mod/flexor modules into SX?
or is it some sort of SX modules?
Looks HELLA interesting tho!
BTW: will this work with any SX version?
Sorry for incompetance :wink:
Piddi
roy thinnes
hi Piddi,
don't know if you ever tried the DeviceManager in CubaseSX; if not: with this thingy you can edit any (hard- or software)synth which reacts on MIDI (sysex or controller) messages.This comes in handy for the Pulsar environment synths, because here you can edit almost everything via CC#s.So here this DevManager panel just controls the various modules of the modular.
Don't know if the SX file I edited will work with Cubase SX1+2 though, I have SX3.Hope it will work for you.
roy thinnes
Just took a look to the CubaseSX manual and it says the MidiDeviceManager is integrated in all SX versions and in SL as well.For those who want to check the patch, a short description of how to install the panel:
-open the MidiDeviceManager (in the Devices menu)
-press Import Setup
-load the CWModularSxDevice.xml file I've uploaded
-select the appr. Midi output of the device (eg Pulsar In/Out1) and Midi channel: 1 (important; forgot to mention this)
-click "open device", done.
Despite having to spend some hours to program the panel (but you can make modifications for other synths if it is done once), I see some benefits that may make it worth the work:
-no preset bug (snapshots can be stored in Cubase); you can exchange Oscs, effects amd so on as you like, just have to assign the appropriate CC value(s)
-clear layout (depends on your own preferences)
-instant access for multi-select parameters like the polyFilters types, wavetable waves, freqDivider values...)
-and, at least concerning my good old Matrox videocard, better and faster handling than the slow Scope GUI
What do you think?
R0zzer
Post by R0zzer »
Wow. Having built a couple of mididevices myself in SX3, I know how much work you must have put into this. Nice one! :smile:
Midi Device PAnels are SX3 ONLY Btw. They will not work in sx1 or 2.
roy thinnes
yep, you are right, sorry. Other inconveniences like the numerous CubaseSX3 bugs doesn't make things better...Nevertheless I created a new SX device http://www.planetz.com/forums/viewtopic ... forum=15&0 Don't know...I like synths with reasonable GUI.
paulrmartin
Post by paulrmartin »
You can do the same in Logic as well. As long your CC numbers are assigned in your Pulsar synths you can do what you want in any sequencer really.
Great work, Roy :smile:
Are we listening?..
roy thinnes
good point! Sh...hope that Yamaha will help Steinberg to fix their buggy sequencer software
soon.
<font size=-1>[ This Message was edited by: roy thinnes on 2005-06-26 17:57 ]</font>
roy thinnes
...but I don't want to start a PC vs Apple / Cubase vs Logic discussion here...
http://www.cwmodular.org/
<font size=-1>[ This Message was edited by: roy thinnes on 2005-06-26 17:58 ]</font>
pseudojazzer
Post by pseudojazzer »
I'm gonna bump this thread - for 2 reasons - first it looks soo cool.. and second i'm being a muppet and cant get the modular to work :sad:
Roy, this is great work! but i'm having trouble getting any sound.. i've checked the guide and dont think i'm doing anything wrong.. i've got the devce map in cubase and the modular in scope - but even without the device map i get midi in lights on the modular but no sound..
is that normal?
Would love to be able to use this if poss - any help much apprieciated.
Thanks,
Tom
roy thinnes
hi Pseudojazzer,
have you copied the Midi Snapshot file in CubaseSX which came with the zip file?
To find out where the Snapshot file ("MIDI Snapshot Generic CC 01-119 80DBD10EDF8941B9BCCEDDE56D628B76") should be stored, double-click a little application in your CubaseSx3 program folder called “open_cubasesx3_application_data_folder.exe”
=> an explorer window will open with the correct path to your Cubase datas. Save the snapshots folder in the “Presets” folder.
If you recalled a snapshot and still nothing can be heard, the reason for this could be:
- wrong Midi channel
- you don't have Flexor
- wrong Cubase version (should be the latest SX3)
roy thinnes
oh, and one more thing: in the meantime Steinberg has removed almost all device manager bugs mentioned in my previous posts :smile:
braincell
Post by braincell »
In Scope it says "Can not Find DSP file OBXFLX". When I try to load it. What does that mean?
braincell
Post by braincell »
I figured it out nevermind.
braincell
Fantastic!
Post by braincell »
This thing is great thanks!
In case anyone is wondering, every single parameter can be automated and much more easily than within Scope which is the beauty of it.
I hope you do more of these.
