eds 16 bug?
MikeRaphone
Post by MikeRaphone »
I dont know why but if i connect individual outputs of instruments to the mixer they peak happily no matter what i do with volume knob(on the eds). Mix output works normally.
Any clues?
Thx
May all sentient beings achieve liberation from suffering :)
afaik, volumes only work for the mix out. you can use the channel gain controls for the individual outs.
MikeRaphone
Thx Gary,
Kick and snare go red though, and i am not sure if they're scorched or not, i put a limiter on it and recorded it, but i wanted to know if it's just a bug or is the signal actually distorted...
Otherwise it's one sexy drum machine :razz:
MikeRaphone
Ergh... so is it a bug?
naoow, can't be :smile:
Did you try to rebuild the project?
I had something similar lately, it was when I loaded the demanding Solaris.
I reloaded Cubase and SFP (after refreshing the prefs of Sound panel and Cubase) to be sure the ASIO communication was reset.
After I did that I didn't see that bug again :smile:
