Latency Compensation
Music Manic
Post by Music Manic »
How do Scope plugins deal with latency when added to plugins within the sequencer?
Will it cause phase issues if signal goes through DSP plugins then e.g. Vst plugins?
voidar
Post by voidar »
Yes it will in XTC mode. This is up to the sequencer, but Creamware have included a delay-compensation plug that should be used on every track without dsp effects.
Or alternatively most modern sequencers will compensate with what is known as 'Full PDC' through their audio engines.
Music Manic
Is the plug found in XTC voidar?
I would like to use the SFP mixer which makes it a little harder.
How would you apply the plugins then?
Music Manic
Could you expand more or point me to more info please valis.
voidar
Post by voidar »
Yes, it is found in XTC.
If you are using regular mode you do not really need to worry about latency compensation.
SFP mixers can be loaded in XTC, but they are not usable beyond 2 inputs and 16 outputs as of yet.
