Is it magic?
Have a try!
96kb swf file.
http://users.pandora.be/copycat/funnyflash/psychic.swf
Any math headz in here?
- ChrisWerner
very nice page, indeed!
With the operation they tell to do you always obtain the number 9, or a number of 2 digit. If you sum the two digit you obtain 9 again.
So you always find the symbol related to the number 9
You obtain a symbol different each time because the matrix of simbols change every try.
If you chose a number > to 0 and > to 9 the game doesn't work.
I'm not a mathematician, so I can't give you a rigorous demostraion, but I think this is related to the base of number used. In this case 10.
I've tried the same algorithm for the hex numbers, but it doesn't work. Probably the formula must be changed a little.
Cheers
Cheers
- Gordon Gekko
