Creamware synths and hardware synth in logic
ramz
Post by ramz »
Hello, I've just bought virtual Minimax and Access Virus (both are great) and I use Logic 5.1 in Windows XP.
I can use 16 midi channels of Virus or 16 midi channels with Minimax or others but I don't know how to use them at the same time. In Logic only appears "Creamware Midi in/out 1" and can use only 1 instrumet (Pulsar or Virus).
I've tried to add a new Sequencer Midi in and out in Scope but in Logic the time line appears in blue and don't works. I think it's a synchronization problem, but I don't know how to solve it.
Thanks.
arela
Post by arela »
hi
No need for a second midi source
At least two ways of doing what you want:
1)
At the Live bar right click the empty slot, and insert eg. a second minimax
As standard the midi channel is "omni", change it to the ch. you want (and do the same in Logic)
Now you have 2 minimax, at 2 dif. ch.
2)
Routing windowSynthsminimax
and set midichannal onm the device itself
Keep in mind your DSP usage, think 16 minimax demand a lot of DSP's.
....good synthing
ramz
Post by ramz »
Thank you!
Now everything works fine. For controlling pulsar instruments from Logic I added two "Sequencer Midi Dest" linked to "Pulsar 2 Midi A Source" and now I have in Logic 5 two Multi-instruments: one for Access Virus programs and other for Scope devices.
Great!
