You may already know, but this is a project I've been following for quite some time, and it seems like they're close to a commercial release. Pretty neat.
http://www.synthmaker.com/
interesting vsti building software
SynthEdit is a pretty deep piece of software & is thoroughly based in C. You have to imagine something like SynthEdit as being an enviroment capable of realising complex custom midi control surfaces for those synths you have without a nice GUI. You know, pick one of your favourite synths which lacks the luxury of a nice computer based editing interface and just make your own
All i'm saying is that SynthEdit's 'sound' doesn't matter in all types of use !
Another difference is that the maker of SynthEdit & also the community encourage & support people with the capability & will, to build (IE program) their own modules.
Any decent synth coder can essentially bulid his own Math mudules, OSC's, Filters & FX mudules giving a Synthedit synth his own sound. Some SynthEdit devs have done this already, giving their synths a different sound from the ones using 'stock' modules.
There is a free version with some minor limitations, but it can still produce a finished item (VSTi) without any reference to SE once loaded. I think the main limitation is that your finished VSTi patch memory locations are limited to 16 & you're not supposed to release anything commercial unless you register it. SynthEdit has become a lot more advanced in the last 2 years, so it may be worth a look if you've not checked it out for a while.
Also, meant to say that I noticed custom module creation is also available in SynthMaker. There's a code window which is a kind of wizard converter claiming to turn DSP code into a custom module ... pretty neat.
