Sonar with ASIO drivers. Which Sw IO module are you using?
ehasting
Post by ehasting »
Hey,
Just wondering what Sofware IO module you are using together with Sonar, when using ASIO.
I am today using ASIO2 24 bit, but i am experiences crashes in sonar when working with the program while running loops from the squence. And it seems to me that the asio drivers is hangs the thing (if not the gfx card :razz:).
rgs
Egil
i use that same driver. it's NOT the asio driver. it's most likely midi, although you should check to see that nothing is sharing an interrupt with your cwa card....it COULD be related to the video driver....
