12 pole analog filterbank
Wired
Post by Wired »
anybody know where i can find a 12-16 pole filterbank, most seem to be 2-4, maybe 8pole
djmicron
Post by djmicron »
6 pole is 36 db, 12 pole is 72 db.
If you really need it, try to connect more than one filterbank for doubling the range.
Wired
Post by Wired »
do you know of a brand out there that has 10-16 pole filter (hardware)
djmicron
Post by djmicron »
i don't know,
but with the modular you can create your own very easily.
What do you need filters that steep for?
Wired
Post by Wired »
not steepness, i'm looking for more depth in the filter with the number of poles, with 2 or 4 pole you crank thru it quickly, but with 12-16 pole, the depth would be huge by many poles overlapping,
Depth? You crank through what?
ChampionSound
Post by ChampionSound »
I wonder why you need that much 'depth' in these filters. For what purpose are you going to use them? Be aware that very steep filters introduce more phasing problems around the cutoff frequency.
<font size=-1>[ This Message was edited by: ChampionSound on 2006-01-22 04:35 ]</font>
nprime
Post by nprime »
I think what you are looking for is greater range in the resonance control. The number of poles in a filter are not "stepped through" as you suggest. The poles themselves are fixed values once selected. As others have already said, the number of poles determines the steepnees of the filter cutoff. Be -6 dB per octave or -24 dB/octave, the steepness is not continuously variable as your response would suggest. The "Q" parameter on a parametric EQ would give you what you want.
R
Wired
Post by Wired »
a guy who creates dopfre modulars told me that their is more depth in higher pole filters, resonance seems more dynamic because of the depth of the filter
Have you tried the filters in modular II/III? ( Flexor? )
