Decimator... irritating noise
Micronesia
Post by Micronesia »
When i open it i get a horrible loud pop!!!
Is this professional?
- Get Creamware Scope - the system that requires you to turn down the monitor volume when opening new FX units!
GAHonGHA!
fra77x
Post by fra77x »
It;s your systems fault. I doubt you 'll ever fix it... Now go by something PRo.
<font size=-1>[ This Message was edited by: fra77x on 2006-02-06 03:59 ]</font>
this is mentioned in the manual, which you should read..and stop whining...
Micronesia
I checked the effects manual on decimator, says nothing.
Please refer to the document or page..
djmicron
Post by djmicron »
micronesia, what do you mean?
I open the decimator without problems....
symbiote
Post by symbiote »
I don't get noise when I load it as an insert either, even when there's sound playing on the channel (STM2448 mixer.)
I think garyb meant manual more as in "general troubleshooting" section than the actual decimator/effects manual.
nah, my mistake!
i misunderstood. i thought your problem was on startup of the system. i've never had a problem with the decimator making a pop....the graphic eq does though, so i turn down the monitors when opening that plugin. i wish i had a good solution for you....
wayne
Post by wayne »
Yep, GraphEQ is the only one that does that here.
Do both mono and stereo versions pop?
May be a corrupt dev.
<font size=-1>[ This Message was edited by: wayne on 2006-02-07 17:59 ]</font>
Booster
Post by Booster »
GraphEQ popping? Deciminator popping? I don't have any effect popping when opening it?!
marcuspocus
Post by marcuspocus »
try inserting grapheq31 on a master channel when audio is playing :wink:
And... what your ears/speakers
Booster
Post by Booster »
I am! No popping, no noise, just a short mute.
What am I doing right? :smile:
petal
Post by petal »
I have that popping too - would like to find a solution for it.... Strange that only some systems have it!?
Mr Arkadin
Post by Mr Arkadin »
Mind you i always think it's foolhardy to insert anything (even hardware) whilst something is playing - you never know what might happen. :eek:
<font size=-1>[ This Message was edited by: Mr Arkadin on 2006-02-08 14:12 ]</font>
petal
Post by petal »
I like living on the edge.... :wink:
Micronesia
I do get a loud incredibly annoying and sometimes scary *zzchhAA-POp!!!!* each time i open the Decimator and both the EQ you mention.
Wierd that some has it and some dont.. Then its about a compability problems.
samplaire
Post by samplaire »
Maybe different ulli setting and different asio modules. There may be many factors to be responsible for that behaviour.
For instance, my friend has pops when stopping/starting playing in Logic while I don't have any. In this case our systems differ much (different audio hardware). But this doesn't lead me to any conclusion like pro or no pro...
Micronesia
I can tell you this, i use samplerate 48khz with Scope as master.
No asio modules are active, i am using another soundcard for that. The Scope only acts as a hardware mixer/effect/synth device...
The only communication is via the Virutal Midi drivers & Adat out & in.
