how can i load different sfp projects from the start
ARCADIOS
Post by ARCADIOS »
is it possible to set different sfp desktop icons that each can load different scope projects, instead of loading after startup?
I never tried this but the following procedure (or a similiar one) might work:
you set Scope to not start automatically with Windows
your desktop icon starts a script that first copies the respective project into startup.pro and then launches Scope
in a more sophisticated version the script would first check if Scope is running, close it and then do the copy/launch sequence
cheers, Tom - never scripted Windows, tho :wink:
<font size=-1>[ This Message was edited by: astroman on 2006-03-14 10:08 ]</font>
ARCADIOS
Post by ARCADIOS »
sorry but i don't get it. a little more help please?
gee, just make a shortcut of the project and send it to the desktop(right click on the file and choose "make shortcut" from the menu).
of course scope will have to be closed to use the shortcut, but, heh...
the idea makes little sense to me because loading a project is pretty darned easy anyway.
djmicron
Post by djmicron »
i think it's possible to setup just one startup project, so, if you launch a project with double click, scope starts with the default startup project and it does not mean about the project you have double clicked.
