FixAttr.bat - batch file to fix 'missing' files issue
Preset lists and tools for Scope modules
Here's a batch file to help with a problem that some users occasionally encounter with Scope installations under Windows XP (especially when installed from CD). The batch file will prompt you for input and give you examples, you must supply your scope path.
Basically what it does is unset the H and R (hidden & read only) attributes that sometimes get set on odd files installed by the Scope installer, typically dsp files and the like. I included simple error checking to make sure you typed the path correctly (although it only checks to make sure that the path exists).
Download the file from the links below, then run the batchfile from anywhere on your Scope computer and follow the prompts.
--Valis
From my site in zip format (avoids some firewall/antivirus apps complaining about the batchfile inside):
http://www.kief.net/studio/FixAttr.zip
Original file here from planetz:
http://www.planetz.com/Pulsar/files/presets/FixAttr.bat
(edit: fixed the html that wound up in this message from a recent forum conversion, and added a 2nd link with the file zipped)
thanks!
krofa
Post by krofa »
thanks a lot. this saved me a lot of headaCHES PROBABLY. I really like planetZ! A forum where you really can find answers...
nightscope
Post by nightscope »
This saved my hide when I got my new machine a while back. Files went AWOL after the install but this rounded 'em up real fast. A belated thanks,valis!!
ns
soylent.green
After two hours of repeated installation...
Post by soylent.green »
...your post kept me from getting very, very, very upset.
This is so silly! CW did such a great job, but there are certain thinks that are pretty annoying. It started with "Cannot open *.rgy file", which was simply due to the fact that I typed in the install directory rather than creating it with "Create new directory"
However, many thanks for your post! Many thanks that you shared your findings!
Can't tell you how glad I am, that I found your posting.
Merry christmas & happy new year.
Peter
balaftuna
Post by balaftuna »
Thanks valis :) !
Brilliant.
dandiggadan
Re: FixAttr.bat - batch file to installation issues sometimes en
Post by dandiggadan »
Thanks Alot Vali!
Awesome mate
DG
Mr Arkadin
Post by Mr Arkadin »
The file seems to have disappeared. so here it is again:
FixAttr.zip
(467 Bytes) Downloaded 426 times
next to nothing
Post by next to nothing »
its still there, just disguised ;)
<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/pre ... .bat"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Related To: Scope installation<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar All Versions Ok<BR> _____________________________________<BR><BR>
The key is to just extract the HTTP adress ( in this case, http://www.planetz.com/Pulsar/files/presets/FixAttr.bat ) and paste it in your browsers adress bar. Just a general tip that works for lots of devices on this site that seems to have disappeared :)
Re: FixAttr.bat - batch file to fix 'missing' files issue
fixed, would have done so sooner had I known it needed it :wink:
