General Midi device synth!
musurgio
Post by musurgio »
I would like to see a general midi synth that would have all the essential General midi instruments ready to be palyed on midi channels.
Regards,
Dimitrios
djmicron
Post by djmicron »
it could be done with sts samplers.
musurgio
Post by musurgio »
Thanks,
I have thought about that.
How can you laod 128 instruments on a sds sampler ?
Regards,
Dimitrios
djmicron
Post by djmicron »
general midi should use 16 instruments at the same time.
ChrisWerner
Post by ChrisWerner »
I haven´t use the sts for a long time now.
But I remember that there are some sf2 or other gm sets in the internet. Try to find one and load it into the sample pool of the sts.
That should to the job.
arela
Post by arela »
This is something added to Band in a Box,
i see they charge a few $
http://www.pgmusic.com/mpu401.htm
Convert the one that came with Gigasampler to STS. It is rather good IMHO for it has more memory attached to the samples, and then compressed for low memory usage.
musurgio
Post by musurgio »
Thanks,
But sds loads only 16 instruments right ?
So you have to manually always unload reload new instruments ?
Also which Gigasampler files are you reffering to ?
Thanks again,
Regards,
Dimitrios
it's probably the Connexant Lib - mine came bundled with GS96, Gigapiano and a soundcard for 60 Euro or something like that :grin:
the single instruments are a boring sh*t (and you'll probably tell yourself '...what a waste of memory...'), but they seem to back arrangements really(!) good and sit nicely in the mix.
On 2006-05-03 01:07, musurgio wrote:
Thanks,
So you have to manually always unload reload new instruments ?...
1 instrument per midi channel, but they can be activated by program changes from one of the 127 entries preloaded in the 'sample pool'
