<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .txt"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Multitrack-looper<BR> _____________________________________<BR><BR> EDIT: FILE DELETED on 12.10.2006. NEW UPDATE-PACK WILL ARRIVE SOON!
Surprise!
Finally i'm leaving tomorrow in the early morning for holiday. Here comes a nice toy for you to play. It's in beta status, no midi control, no good monitoring & in/out management, but you can make wonderful music with it also with this early beta.
Record 8 independend mono loops! + overdubbing. Every loop gets it's own length.
have fun!
Martin
EDIT:
LOOP-layMM1 released.
- all values MIDI-controllable
- Presets working
- In2All - button (now you have the choice: pushing record button for indiv. tracks, or using the long 9-state fader...
- green Out - bug removed
- influenced the sound by some mystic crystals and numerated the tracks.
EDIT:
Hoppla... there are still a few things to correct.
- Added KILL ALL
- Fixed: Now only delayed (wet) signal comes out of the single outs - you have to connect the dry output (OutR) to a mixer to be able to hear what you're playing
- Outputs are green again... I will fix it later
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-07-31 03:34 ]</font>
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-10-12 05:32 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/dev ... timono.jpg" BORDER="0">
LOOP-lay MM 1b
An insert point for each 'track' would be spectacular... it would be fun to pitch-shift individual tracks.
I don't know if this is possible in your design, but it would be really nice to stop/start/re-sync the device with a MIDI note - MIDI clock in Scope is pretty flakey unfortunately. A MIDI note gate is used in Flexor sequencing.
Have a nice holiday
<font size=-1>[ This Message was edited by: darkrezin on 2006-07-12 16:04 ]</font>
Have a nice holiday
darkrezin, it's based on my looper patch. Retriggering doesn't work with delay lines. Also, any insert would do so accumulatively, so changing the level a tiny bit could result in drastic changes in the loop's sustain...
not sure, michu, but here's some for people who wanted to put an insert in the loop:
WL's Infiniti2 and http://www.deviceplug-ins.com/infini.htm .
Will search for it some more, Michu...
Back from holiday!
Some brief comments (I have to really arrive first-it's as hot in germany as in france and I had a 10-hours-car-trip today...):
The single-outputs of the device are green ;o), sorry, I will try to change, but... who cares?
You can use the "KNOTTpack"-devices for inserting after the single outs.
I think for experimental inserting in the loop-path the Stereo Version of LOOPLAY is perfect. You can use multiple LOOPLAY-stereo instances along LOOPLAY-mm.
I hope I will find the time to put some work in this device soon. Point 1 for me is MIDI capability (I mean MIDI control for all parameters), Point 2 is multiple inputs.
Adding inserts for each LOOP-line is not really that interesting for me, because LOOPLAY-stereo (or the use of "knottpack-devices") fits well that aim, I hope ... If you really, really need it... we'll see...
Martin
P.S. I managed to build a workaround for the MIDI sync. Signalchanges are slown down, so it works, syncing this device to a sequencer! (As far as I remember - It works for sure with LOOPLAY-stereo!)
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-07-25 07:29 ]</font>
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-07-25 09:15 ]</font>
Martin
I won't add multiple inputs. It's O.K. this way, I think. Added an In2All Button, so recording with midi-automatation should be easier now.
For multiple inputs, I think I'll rather make a 1MONO-version, which can be used in multiple instances as Loop-lay STEREO.
This device is very time-consuming because of it's gigantic circuits. I'm very happy to have presets working. With the Presets I had to start from the beginning 3 times, because it's very difficult to find a mistake... puh.
Martin
Martin
