Video codecs
lagoausente
Post by lagoausente »
I have some videos I have dowloaded form internet. When try to play them, can´t find the codec. I know I can install a codec pack, but I want to send them to a friend that may not have the codec pack.
I need a tool to can convert them to a standard AVi, or MPEG, to can see them without a specific codec. Can you recomend me one?
ChrisWerner
Post by ChrisWerner »
virtual dub
http://virtualdub.sourceforge.net/
free fast good
<font size=-1>[ This Message was edited by: ChrisWerner on 2006-08-27 08:31 ]</font>
lagoausente
Thanks!
skwawks
Post by skwawks »
There is program called GSpot which identifies which codecs are installed and can point you at the ones you need . It's small and free but it works :smile:
eliam
Post by eliam »
vlc media player reads everything that no other player does. It's my favourite player, very light and efficient! And it's free!
braincell
Post by braincell »
lagoausente
VLC player worked well.
Virtual Dub cracked on my system, don´t know why.
Zer
Post by Zer »
I strongly recommend nero show time (just download the demo of the nero package from ahead) and in addition the k-lite codec pack of http://www.free-codecs.com. Best video player I tested so far.
k-lite video codecs will allow any windows app to play back videos. Keep in mind there are different options at install as to what codecs get installed, most normal codecs should be accounted for by the default installation options.
Personally I'd suggest avoiding Nero 7 unless you need it for a modern HD-DVD/Blu ray burner as it now comes with a less than stellar payload that get installed as well (not really spyware, but comparable).
Zer
Post by Zer »
yeah...but once the demo ist inatlled you can delete everyrhing except nero vision an nero showtime, and probably you are able to get V6 demo as well. The standard codecs should be played back fine withou additional codecs. It was just a hint.
ali
Post by ali »
CCCP codecs is a must have.
http://www.free-codecs.com/download/Com ... c_Pack.htm
VLC player is also better than any players out there for video.
<font size=-1>[ This Message was edited by: ali on 2006-09-05 13:02 ]</font>
darkrezin
Post by darkrezin »
Zer
Post by Zer »
Sorry. absolutely not, It crashed on five systems I tested it was lame and the menu was cryptical and it is overburdened. When it comes to playback I don´t need an info machine or a meta data writer or a networking broadcaster. I need a simple program easy to use, small (even in size) and a fast skiled worker, not an allrounder.
darkrezin
Post by darkrezin »
VLC? That's insane... you must have got a bad download or something... it's very stable for me and I've used it on countless machines.
ali
Post by ali »
that is very weired Zer
I like darkrezin have VLC player installed on so many systems.
Something ain't right ZER with the version you are using.
but then again no 2 pc's are alike
braincell
Post by braincell »
Why is it a network viewer? That seems suspicious to me.
Zer
Post by Zer »
I don`t care. I found my (ab)solution.
