Is my Pulsar2 card toasted ?
David Van Huffel
Post by David Van Huffel »
I suspect for a while now that something is wrong with one of my 2 pulsar2 cards. I tested my system by trying to fill up everything the DSP's have to offer. SFP refused to allow me 6 dsp's, which is a first indicator to me. He complained about STDM cable, but these seem ok and are firmly attached.
I fiddled around with the breakout connector a bit too much (it was not firmly attached) which must have caused something wrong I guess.I got a "connection error".
Now Windows XP refuses to recognize both Pulsar 2 cards. XP only finds ONE pulsar 2 card, not two. That one card seems to work fine.
What can I do ? How can I know if the hardware is toast, or if simply some setting/installation is the cause.
And if there's something wrong with the hardware, has anybody ever had a creamware card repaired ? The card is too old to have any warranty, so I'd like to know if there's any repair possible and what it would cost...
Thanks,
David.
yes, cw can repair it.
it sounds broken, but there could also be a bad cable whip. try starting the computer up with the affected card's whip removed and see if it appears in the os again, otherwise, contact Ralf...
H-Rave
Post by H-Rave »
What does it say in the device manager ?are there any conflicts ?
On 2006-08-31 09:26, David Van Huffel wrote:
...I fiddled around with the breakout connector a bit too much (it was not firmly attached) which must have caused something wrong I guess.I got a "connection error"...
the card might have lost it's fixed position in the slot.
I'd revmove all external connectors, then lift both cards and put them in again - pay attention that they really slip into the slots deep enough, then tighten them to the back of the PC case.
Attach only the S/TDM connector and and leave the cable whip(s), then start SFP and check the DSP meter.
A broken cable whip can paralyze a card, say by setting clock to ground or similiar things.
The cable whip is easy to open and to inspect if something is broken/loos inside.
good luck, Tom
Ralf
Post by Ralf »
please remove the cards ( both ) out of your system and clean its contacts ( PCI & STDM ) with pure alcohol. Put the cards again in the system ( use other PCI-Slots if possible ) and boot again. If it is required, install again the hardwaredrivers. If this doesn't fix the problems, so please write me an email "rb[at]creamware.de" and ask for a RMA-number. Mostly we can fix such problems. Out of warranty this will cost 100 € + the shipment back to you.
cheers
ralf
Thanks,
David.
David Van Huffel
I removed the cards, cleaned the contacts and put them back, one by one, without breakout cable. The results are good, I can use all DSP's, yippy ! I only got one error that said there was an "unexpected DSP limit reached", but that one didn't reappear so far.
Next test is testing with breakout cables. I connected all cables, firmly attached. I seem to have some problems with my midi cables, but this can also be due to the fact that it's 00h40. I will continue the tests tomorrow.
Many thanks for your help and usefull hints. I hope my installation will be back on its feet soon.
if the cable whip is bad, a multimeter and soldering iron can fix that, or you can buy another.
i'm glad it's working!
<font size=-1>[ This Message was edited by: garyb on 2006-08-31 20:32 ]</font>
