PulsderZeit 8X +/- 24db EQ
MCCY
Post by MCCY »
<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .txt"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Effect<BR> _____________________________________<BR><BR> EDIT: FILE DELETED on 12.10.2006. NEW UPDATE-PACK WILL ARRIVE SOON!
... nothing more, nothing less...
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-10-12 05:47 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/devices/Pdz24.jpg" BORDER="0">
hifiboom
Post by hifiboom »
well done MC! looks better now.
you still need the boxes around the text?
I would use just plain white text on the backround whithout the boxes...
and still: its more heavy on DSP than the EQ its modeled after. :grin: :lol:
The original may just be 18 or 24 dB EQ with 4 bands.
In fact yours has 8 x 12dB bands which will double your hit on DSP load.
And the usage with 4 knobs + Q per band is quite strange ATM.
:smile:
Anyway thanks...
<font size=-1>[ This Message was edited by: hifiboom on 2006-09-12 03:59 ]</font>
<font size=-1>[ This Message was edited by: hifiboom on 2006-09-12 04:00 ]</font>
MCCY
Post by MCCY »
No modeling anymore ;o)
P. is 12db per band... P. is one band +, one band - values...
With this EQ you can set + & - values with each band as u like and as it's usual with EQs ;o).
24db circuit needs simply double DSP.
Yes, I could make a button, to take second EQ from DSP, if just 12db needed, but there are enough 12db EQs out there...
So it's a 16x Parametric EQ (with 8 doubled 12db EQs) - nothing more, nothing less, nothing special. Special may be, that you are able take every 2 EQs from DSP...
I'm working on something special though ;o)))
Martin
Btw.
"And the usage with 4 knobs + Q per band is quite strange ATM."
Per band? You just have 8 parametric bands now. One knob for freq, one for Q, one for gain. Thats a standard, i think.
EDIT:
and oh... I forgot... the old phase-issues are back ;o). I allready corrected it and will upload it later...
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-09-12 05:38 ]</font>
hifiboom
Post by hifiboom »
Martin
Btw.
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-09-12 04:59 ]</font>
okay you say its 8 x 24db (2x12db) paramteric EQ? So it will cost 4 x the standard PEQ4 form CW...
So I undertstand why its a DSP_hoog.
:smile:
okay I understand....
but why did you arranged them each 2 together and made them switchable on/off 2 together...
Don`t understand your graphical arrangement then...
First I thought you have 2 x 12db arranged together to reach 24db Gain...
But now I see that ist 2 x 24dbEQs
MCCY
Post by MCCY »
It just grows... I'm not that straight worker, who's steps allways make sense. Otherwise I may loose the fun of it.
I like to group things, so that it's easier to count... but that's a matter of taste. I could write numbers too.
I have enough DSPs, so there is no need in an on/off button for each single EQ.
As with dynaMYTH I see that I just share my personal (for others not allways easy to understand) devices with the pulsar community. I'm thinking 'bout taking at least a little bit money in the future for some devices for various reasons - but that's not decided so far...
Martin
MCCY
Post by MCCY »
B.t.w. hifiboom, thanks for your design-tips! White letters without light box look very good!
... but sorry, I'm working on a completely new version which won't be released too soon...
Martin
hifiboom
Post by hifiboom »
Martin
Jip! no problem.
IMO, these boxes make the device look overloaded and do not help in anyway.
:smile:
All you need is a good background bitmap, a contrasting easy to read textstyle and shroomz nice GUI elements...
And of course some unique algorithm behind...At least that is what really counts...
:smile:
best regards...
<font size=-1>[ This Message was edited by: hifiboom on 2006-09-12 07:21 ]</font>
Shroomz~>
Post by Shroomz~> »
Thanks Martin :smile:
MCCY
Post by MCCY »
I have to thank you! It's so wonderful to work with the new potis!!!!!
(I will build in credids in the next update.)
Martin
