K1-B Knotts-Scope-device-collection 1.0 Part 2
MCCY
Post by MCCY »
I removed all old versions in the forum.
K1-B- This package part 2 contains the whole Helpers, Loopers, Samplers.
For "GUTU" you need Adern Flexor registration.
HELPER_LOOPING_SAMPLER.zip
(6.17 MiB) Downloaded 1304 times
Lima
Post by Lima »
Martin, thanks again for your HUGE contribution. I very appreciate the new zip, CIAO! :smile:
MCCY
Post by MCCY »
P.S. Any device which holds inserts has to be renamed to *.dev when using presets on those inserts. Sorry. Corrected that for "dieknotts", but there are other devices, which could need this modification when working with presets.
Ben Walker
Post by Ben Walker »
Hi Martin,
couple of questions about these as I was having session trying some of them out last night.
1.) The modular ZAM's seem to be monophonic. There's no way to connect them to an MVC and I could only get monophonic output from them. Am I doing something wrong. I know these are still only work In Progress, so it may be that that's how they are at the moment.
2.) LooplayMM - when I change the master BPM (with the clock set to internal) I expect the delay time on the individual delay lines to change but it does not. Am I misunderstanding how it should work? Also how to get the click track to click? Again, I know these are beta devices, but any advice would be much appreciated.
Thanks again for your amazing contributions!
Ben
MCCY
LOOPLAY&MODZAM
Post by MCCY »
Hm. In both cases it should work as you expected. MODZAM is polyphonic I will try out now where you have to set it ;) I never worked with MODZAM so it seems did anybody else, so I dropped developement on it, but it should work polyphonic.
Looplay should adjust delaytime with changing internal clock, if not I screwed up something with the updates. It worked before. Will try out this now...
Martin
MCCY
LOOPLAY screwed with update
Post by MCCY »
Looplay is indeed screwed by the big update. You can't change tempo...
I have not the time to fix it by now, but I will post the old versions IN THIS POST...
You have to set polyphony under "presets" button. It's the old presets-style.
Martin
hmmm... LOOPLAYmm doesn't seem to work ... have to take a look later. Sorry.
Shroomz~>
Post by Shroomz~> »
I liked your sample players a lot & we'll use them for sure (especially MODZAM), so I hope you finish them & maybe even add some additional features when you have time, because they're really usefull devices.
MCCY
LOOPLAY MM1c (repaired)
Post by MCCY »
Found the LOOPlayMMbug. Sorry. Now it should work!
Update to LOOPlayMM1c comes with this post!
martin
It's in the package now too!
LOOP-layMM1c.zip
(434.79 KiB) Downloaded 420 times
FrancisHarmany
bypass for the auxknott
Post by FrancisHarmany »
awesome package! I keep wanting more features tho ;p
It be nice to have a bypass button on each channel of the 1-8 , 9-16, ... , auxknott devices. perhaps you can make the numbers for the differnt rows clickable, and have the colour change indicating all the effects are bypassed or not.....
