dynatube and low cut
bosone
Post by bosone »
i'm using dynatube feedde by my guitar passed through a presonus tube pre.
i found with a spectrum analyzer (voxengo SPAN) that there are a LOT of bass frequences in my signal (expcially with distorted guitars).
i tried to insert before dynatube the flexor highpass 8 pole (using McCyrano insert modules).
i think that the sound is much better in this way... have you any similar experience??
well, i'd do the same thing with a mic'd guitar cab(use a low cut filter). low freqs build up mud pretty fast...
Mr Arkadin
Post by Mr Arkadin »
Putting highpass/low cut on guitars is pretty standard for clearing up a mix.
<font size=-1>[ This Message was edited by: Mr Arkadin on 2006-10-19 02:38 ]</font>
katano
Post by katano »
jep, agree...
on almost every instrument in the mix...
voidar
Post by voidar »
I always boost the plugs with an MXR-10 band around 500-800Hz going into my pre-amp.
Tightens them up and gives more cut.
bosone
Post by bosone »
i agree to your answers, but the point was to use highpass on the dry guitar signal, before it comes to dynatube!
i feel that a signal with a lot of basses is not so good for dynatube, expecially with heavy distortion...
katano
Post by katano »
i would say let your ears decide. it's really simple to compare, as dynatube has pre and post inserts. just load an eq and listen...
voidar
Post by voidar »
This thread seems to have been deleted:
http://www.planetz.com/phpBB2/viewtopic ... 650#158650
