please somebody help me (optical cable)
karali
Post by karali »
i have pulsar 1 card and i used to work with analog behringer mixer , but now i have yamaha 01 v digital mixer with aes/ebu card , but i don't know how to make conection .
- what cable should i find and where ? , to make conecton between aes/ebu card in yamaha's mixer which have 25-pin conector on it's side.
-i think that i can make conections with optical cable
JOVICA KARALI
the cables are called TOS-Link, you may take the plug that closes the connector on the backside of the mixer to the shop, if in doubt.
(not to mess it with another type of optical connector that's used with hi-fi gear)
btw, nice location where you're from :)
kylie
Rank-o-phile
Post by kylie »
astroman wrote:the cables are called TOS-Link, you may take the plug that closes the connector on the backside of the mixer to the shop, if in doubt.
I'm in doubt that the toslink plug will fit to the db25 connector he mentioned...
karali, why did you, btw, open the question again here? well, the devices forum was surely not exactly the right place for it, but my answer will be the same here (even if you dislike it :) )
-greetings, markus-
karali
conector
Post by karali »
i'm not shure can i make optical conection betwin (my-8 aes/ebu card) in yamaha 01 v and pusar 1 card to use 8 in/out digitaly and make mix on yamaha 01 v .
-is my-8 (aes/ebu) is right tool or i need adat card ?
-what cable i need to use ? .
p.s. yamaha's my-8 aes/ebu have 25-pin jack(conector) on it's side
btw i'm from ohrid , macedonia
the most beautiful place in the world , with lake that is protected from unesco becouse of it's unique and beauti,and rare natural speaces that lives in.
you are welcome any time to be my guest ........(beach,water, hot somer,party)
JOVICA KARALI
kylie
Rank-o-phile
Re: conector
Post by kylie »
karali wrote:i'm not shure can i make optical conection betwin (my-8 aes/ebu card) in yamaha 01 v and pusar 1 card to use 8 in/out digitaly and make mix on yamaha 01 v .
aes/ebu is NOT optical, so you can't. sorry. if you want to use 8 in/out with the pulsar, go with an adat board. there is no cable that wires db25 electrical to fiberoptic toslink. the format the data is sent is different, too.
it's the already mentioned toslink-toslink. you could still use a format converter, but they are expensive.
maybe you are lucky getting an adat board cheaply from ebay.
-greetings, markus-
i thought the 01V has (at least one) Adat port as standard, doesn't it ?
kylie
Rank-o-phile
Post by kylie »
astroman wrote:i thought the 01V has (at least one) Adat port as standard, doesn't it ?
the picture in the manual does not mention one. spdif rca is there, but all other digital i/o seems to be done via option boards.
the feature list in short words:
there are 24 channels max, while 1-12 are mono in, 13/14 and 15/16 stereo in, and 17-24 digital ins, IF an optional card is plugged in. and there is already one, the aes/ebu...
-greetings, markus-
oops, probably messed it with the 01V 96 (at Thomann) ...
kylie
Rank-o-phile
Post by kylie »
astroman wrote:oops, probably messed it with the 01V 96 (at Thomann) ...
the 01V96 has adat on board, right :)
