Nuendo, Samplitude, & Scope?
Hangee_77
Post by Hangee_77 »
Does anyone know how to transfer the Nuendo2 project (consists of audio & VSTi tracks) to Samplitude8?.....and when I use Samplitude & Scope, what software IOs modules (ASIO, MME,….) should I use in Scope?
hc.
manfriday
Post by manfriday »
not sure how wel vsti's would transfer from nuendo to samplitude. I've only ever transfered audio and midi between applications...
When using samplitude and scope, I would advise you to use the ASIO2 modules. Works wel for me.
ChrisWerner
Post by ChrisWerner »
I don´t know samplitude but maybe you can export your Nuendo project to a file format that is included in Nuendo and Samplitude?
just export each track in nuendo so that you get contiguous wav files for each track and then import them into sam.
siriusbliss
Post by siriusbliss »
I'm not sure, but perhaps the EDL translator would work also - if you have markers? Again, not sure.
Otherwise, yes, just export full .wav files and import them into Samplitude. Easy.
VST"s would probably have to be re-applied inside Samp.
