Control surface
titodave
Control surface
Post by titodave »
Hello!
I´m searching for a control surface (midi) for cubase sx 3.1 and scope mixers...
Can i do that with TASCAM US-2400 ?
Do you know another solution for me?
Thank you from Spain and sorry for my english!
irrelevance
Post by irrelevance »
Have a look at the berihnger BCR or BCF2000 controllers. Very cheap but quality seems good. Give a visual feedback with LED's and the BCF has motorised faders.
moxi
Post by moxi »
or build yourself your own MIDI surface that perfectly reply to your needs:
www.ucapps.de
you won't find better ;-) !
Lima
Post by Lima »
moxi wrote:or build yourself your own MIDI surface that perfectly reply to your needs:
... Like this one :-P
That is awesome !! Do you use one 4 SFP? This looks like a very customisable item. Sweet.
Thanks 4 The Hook-Up,
irrelevance
www.ucapps.de
Nice link moxi! Sequencer project looks very interesting.
moxi
Post by moxi »
here is the seq I've build, it's a really awesome gear, with a perfect timing, and the next update will let you use it as MIDI controler too in the same time! :
on the other side I use the MIDIbox64E to control the scope Mixer and some synth.
I hope one day creamware cards will support the Mackie protocol cause it's possible to build a mackie control emulation with the MIDIbox project...If the new boss can read this.... :) , or at least will add some usefull functions as automap for easy setup of the midi controls...
Is it only a step sequencer, or can you do real time multi-track style?
This forum is full of talent.
moxi
Post by moxi »
it's a step sequencer, but you can have from 1 to 32 steps per bar (you can set different number of step for each track) then set the track to play twice, 4th... faster (or slower) and you can chain tracks...(there is 16 tracks, each with 3 layer that you can assign to notes, CC, velocity... (so you can play chords if you need)
this way you can trigg up to 48 note events at the same time!
It's not possible to record multiple track at the same time, in fact I use it to create quickly some great patterns (and to tweak them in real time) -like using Fruity Loops- then record in Cubase one time my set is what I need, to do more fine mixing. This sequencer is for live tweaking , it's not the same way of thinking than cubase or Logic.
the fact that a lot of parameters can be directly tweaked lead to different creation, it's something hard to explain..
I know, that's why I'm interested. I've used hardware sequencers for years for FX, lighting, Prgmd tracks. They are so dependable also, as they have one function. Could I have some sort of PDF on this if possible. I really love that major DIY look. Hardware toggles are sweet !
Please speak of this more,
Jimmy V.
Lima
Post by Lima »
I use it for SFP: for mixing and for controlling some synths.
You're right Jimmi, it's very customizable! It has 16 bank of 16+8 controllers (16 for the knobs and 8 for the switches) and the parameters are freely assignable. But its best feature, in my opinion, is the speed of sending the CC. And think that it is the smallest of the family: for example there's a project with 64 controllers and support for motorized faders and encoders...
:-D
moxi
Post by moxi »
the best way to know how it work is to rerad the tutorials:
http://www.ucapps.de/midibox_seq_tutorial1.html
and to read all the related info on the ucapps.de web page, cause a lot of infos can be found in many place on the web site..
For this one, there is more function than I really need! you can even drive analog gear via CV, route parameters of a track to another parameter of another tracks, and a lot of things that will be to long to list.. And it's the same thing for the MIDI controlers..
If the construction is done with care, this project can really be equivalent or better than commercial controlers....
really great stuff Moxi! :-)
Brotha' Man Moxi,
DIY is not one of my strengths, is there a specialty shop in Deustchland somewhere, where I could send a design, and have something built ? I'm hoping to have mixer surface that could go to Solaris, and ProWave templates as well. This dog just might hunt.
Honestly, I Could Fuck Up A Steel Ball, Safety First,
bassdude
Post by bassdude »
Wow this project has really advanced since I last took a look years ago. I think I'm getting the itch to build my own mixer control surface now.
Stuart.
titodave
Post by titodave »
thank you very much!!! :o
Jimmy, there are quite a few users out there who will build stuff for you. You can order most of the necessary parts and premade circuit boards from various forum members at ucapps & midibox.org if you start hanging out there.
There's also a #midibox channel alongside the #scope channel in EFnet. themuted there built quite a few Mackie Control emulations (among other things) that have had me wanting to build my own for a few years now.
I can't figure out how to get back in there @ EFnet. Alfonso sent me a link up but I think I have to download something from JAVA right?
@ any rate, thanks 4 the tip Val. I shall try again in the morning.
irrelevance
Jimmy do you mean you need a chat client? Mirc is a very good chat client and there is minimal setup involved. I've never checked out the scope channel on efnet though.
I'm very interested in this project. Moxi already received my thanks in a pm :)
If you check in the www.ucapps.de wiki there are links to online vendors offering kits:
http://www.mikes-elektronikseite.de/sho ... /index.htm
Makes the process very straight-forward.
I've actually got a link at RS components uk so if anyone if thinking of ordering individual components for this sequencer project let me know and hopefully I should be able to get a good deal.
NAS
Post by NAS »
Mikes good for kits but smashTV is much better
Higher quality PCBs and smash is always updating his designs to make construction simpler
http://www.avishowtech.com/mbhp/
Most of the time you will find him on the IRC too
