setting up scope
hollo321
setting up scope
Post by hollo321 »
hi im setting up my scope pro card for first time. after installing card and drivers should i install sfp 4.5 software onto my C: boot drive or K: storage drive for best performance?? same question for plugins
thanks
c drive.
minipax
Post by minipax »
mmm, i just installed Scope on my storage drive last night...whoops.
so, install the exe on the OS drive and then save all the project files,samplebanks etc... to the Storage drive...would this be the ideal situation?
Herr Voigt
Post by Herr Voigt »
Yes. Project files and samples you can install wherever you want. I save my projects in the same sub-folders as I do it with my Cubase-song-files. And for my samples I reserved my whole drive F:. Scope will find it all.
Installing the scope folder on drive C: is pretty recommended. Sometimes we've had a discussion about this topic here on Z. Installing Scope on another drive could cause problems.
Cheers, Thomas
kylie
Rank-o-phile
Post by kylie »
I may be lucky, but my scope drive was d: from the beginning. no spectacular problems so far...
-greetings, markus-
ChampionSound
Post by ChampionSound »
Herr Voigt wrote:Yes. Project files and samples you can install wherever you want. I save my projects in the same sub-folders as I do it with my Cubase-song-files. And for my samples I reserved my whole drive F:. Scope will find it all.
Cheers, Thomas
Yup, same thing here. I installed scope itself on drive C:,
The Scope project files and cubase songs are put together in a folder (each song has a folder) on another drive. Works great.
