Scope synth Unison Mode?
10nMax
Post by 10nMax »
Hello! Scope Platform for me nova and so appeared several questions.
- There is in synthesizer Scopе synth Unison Mode? Unless in all then in what?
- Exists Virus for Scope?
- And if not difficult prompt, what in general synthesizers you have advised (including pay) have in cartridge clip what moments beside they are got better, leads, basses, pads.....
Beforehand Thank you!
10nMax
Post by 10nMax »
Yes you rule. I do not speak english=(. So have recourse to electronic translator....
stardust/// Thank you for detailed and fast answer, shall study further, long varied before buying Scope, but comfort and logic of the interface has pleasantly surprised.
10nMax
Post by 10nMax »
I from Russia, such russian-language resource on Scope probably no on the strength of small spreading.
Wanted else to ask about analyzer of the spectrum... why that under Scope does not work PINGUIN. In most analyzer is specified driver Scope, but in mixer on output is connected Wave Dest.The signal goes On entry mixer.
Exist analyzers of the spectrum under Scope?
Or good analogues PINGUIN.
The Approximite sets like Voxengo CurveEQ and Elemental Audio Systems plugins. Where is directly shown in graphic type Signal and parameters EQ in real time.?
Certainly in XTC with them to work possible, but not to want to use this cut since much liked mixer Scope.
King of Snake
Post by King of Snake »
alfonso
Post by alfonso »
10nMax wrote:I... why that under Scope does not work PINGUIN..
It works perfectly with Scope. if you connect the Mixer output to a Wave destination module, it will work. Check Pinguin's settings.
raztalove
Post by raztalove »
im having the same problems getting pinguin to work as well. My settings in Pinguin are correct. I chose "creamware play/record ".
I am positive that the routing in pulsar is correct. Ouput of mixer goes to wave dest 1, yet no signal reaches pinguin.
Is it because Im using 32bit flt?
Any tips would really help out. Thanks
RL
