I need your help. I have 3 cards a pro with 24 adat i/o plate, a project classic i/o and a luna (3 dsp). I followed the suggestions from the forums and made sure sfp was uninstalled rebooted system without cards. Then installed cards with s/tdm connecting to each card and let windows install the drivers first before installing scope 4.0. I modified the cset.ini so that the larger pro card is 1 project card is 2 and luna is 3. All dsp and hardware/software I/O are present in the menus. All work except for the adat I/O on the pro card. When i connect the adat it shows up as active in the samplerate box but the audio that comes thru it is chopped like a rapid tapping sound.
All the other I/O on the other two cards work it is only the adats on the pro card.
Is it neccersary to rebuild all the projects within SFP or just the default one?
Does anyone know what would cause the signal to playback that way or had this problem?
