MONSTERpitscher 2b (dsp variable)
MCCY
Post by MCCY »
Keyboard-playable pitching-enginge with 24 voices (one Octave up & down from center C). Unfortunately it uses MORE THAN ONE SCOPE PRO BOARD when full 24 chromatic is set!!! Sorry. I don't know, if I can get a fixed to less voices but still modulatable pitching polyphonic version working...
There is still one option for a compromise left: Enabling & disabling unused intervals, what about that?
So this was just a fun-projectso far - listen to the mp3.
EDIT:
- dsp variable
- set your own scales
- preset-file added
EDIT:
Sorry MoPi2 - release delayed
EDIT:
MoPi2b released
MoPi2b.zip
(444.86 KiB) Downloaded 632 times
MCCY
Post by MCCY »
Another solution could be to make a 2-3 voices version where you have to play the different voices on different octaves on the keyboard.
MCCY
Post by MCCY »
MoPi 2 added.
Lima
Post by Lima »
The MP3 is really funny!!! :lol:
The device seems very powerful! Thanks!
(unfortunately I've got only 10 dsp... :-( )
nice experimenting Martin :-)
MCCY
Post by MCCY »
Boa, wir sind auch echt selber schuld hier in der Community... - in Sachen viele DSPs - seit einiger Zeit scheinen die Scope-Preise ja mehr als stabil zu sein! Sie waren schonmal billiger.
Wenn man dann mal jetzt auf ein Pro board mitbietet, gehts gleich an die Tausender-Grenze. Ich habe das Gefühl, dass da die freeware-plugins eine nicht unwesentliche Rolle mitspielen. Natoll, versau ich mir also tagtäglich selbst das Scope-Schnäppchen ;) ... Bin nur froh, dass ich schon meine 2 Pros, 4 Einser und 1 Luna untergebracht habe 8)
B.t.w. the actual version is usable on smaller boards too. With every halftone you activate dsp-consumption rises. So if you only need some specific intervals or an upwards-major-scale, it works fine on smaller boards too. Only the fully chromatic needs serious dsp...
MINImidiPITSCHA is a very good alternative when you'd like to go chromatic but don't need more than 2voices polyphony. Just set up 2 MiMiPis & allocate them to areas on your keyboard. Now you can play 2 intervals in addition to the original sound without wasting dsp power...
Ladies And Gentlemen,..........................................MCCY.
I just took a break during rehearsal.
Nice pause.
I will post on this Tuesday when I get back to Vegas. Presets too !!
Real nice sound.
BTW I just bought a PCM81 for a killer 900USD w/ extended pitch algo cards.
If you can get this to sound as good as the Lexicon this place shall rejoice.
MCCY
Post by MCCY »
I knew it all the time, that 10x power would come soon... So now that there will be 10x power soon, this device will be normal to use. :D
pollux
Post by pollux »
the mp3 download link is broken :(
it is.
MCCY
Post by MCCY »
Sorry, so i'll have to do a new one...
MCCY
Post by MCCY »
You don't need presets for thisone. Just enable some halftones and play keyboard via midi-in while you put something in the input... It is just a realtime-playable pitcher with settable scales... The more halftones you activate, the more DSPs will be used...
Don't forget to try the "mini-midi-pitscha" if you like the idea behind this. Thatone is really usable on small systems. You can use several units spread over the keyboard to get the polyphony of your desire...
I really wonder why so few people recognized all these midi-playable effects of mine... I bet it's because of the poor GUIs ...
