I'm looking for a switch module that has 1 in and 4 to 8 outs whose routing can be controlled from a sequence module, a trigger or any other modulation source.
Right now I'm using a sequencer in Numerology and sending the data as a CC to the normal 1->4 switch but it would be much easier if there was a module with a control input for the output selector.
Thanks in advance for any info you can give me.
3am
sequence-able 1->4 switch module?
First off, this post should be in Device/Module Wishlist. The Devices section is for posting, euh, devices.
Sequenceable? Check out Flexor's Granular Sequencer! See here and here.
I remember this MIDI controllable output selector, but I forgot its name and since the Scope machine here is waiting on a replacement for its fried motherboard, I can't check it for the name of that device... Anyone else? I think it was dark blue/purple, and had like 8 outputs...
Greetings,
at0m.
Greetings,
at0m.
