LSR 4312SP subwoofer?
djsainz
Post by djsainz »
I have a set of LSR4328P and I was wondering if anyone has the subwoofer to tell me how it sounds of its its worth getting a subwoofer for those 20Hz sound region.
The music I mostly produce is Electronic based music.
David.
Mr Arkadin
Post by Mr Arkadin »
i don't know your speakers but if you have a small room i would say avoid getting a subwoofer, and if you have a big room then get bigger speakers with a bass end. i personally don't like the 'artificialness' subwoofers introduce and would not use them whilst mixing - how do you gauge the correct level for the bass end?
Mr Arkadin wrote:how do you gauge the correct level for the bass end?
by setting up the system with known mixes that you like.
a sub is a great thing, but your room does need proper bass traps or things will get so muddy that the mixes will suffer.....
Mr Arkadin
Well yes, but what i meant was they often have they're own volume knob, so i would say that most people would set them up bass heavy because they like lots of bass - giving a false sense of what you're actually mixing, whereas a speaker with a woofer and tweeter will be matched.
Don't like your mix - just turn up the knob - problem fixed :D .
:D
that's what i meant too. what is the proper amount of bass with other productions will lead to the proper amount of bass from yours. i agree, though. whenever possible, i'd like the sub to match the other components only extending the range of the system, not necessarily pumping it up. when mixing, you want accuracy, not impressiveness...it's nice to find out what is happening down real low, because many systems are reproducing those freqs these days, but a balanced mix on a good pair of nearfields should be balanced almost anywhere...
djsainz
Post by djsainz »
These monitors and subwoofer system are all interlinked via network cable to eahc other and USB to the computer, so all parameters are automatically ajusted to extend the frequency range of the monitoring system with the volume at equal level throught the system, so no danger of getting wrong impression if you have a louder bass volume
the room is the real problem....
adding bass to a bad room is a bad idea.....
djsainz
Post by djsainz »
That is also true, but the reason i chose this system its due to its Room Mode Correction, simply plug in the calibration microphone into one of them, run the RMC button once so it analyses your room acoustics and wow first time i ran it, what a difference, fresh out the box the speakers sounded awesome, but bass was vibrating half my room, after RMC, the bass was super tight and clean.
Mr Arkadin
Yeah, doesn't matter what your computer says, garyb is right, if your room can't take that bass extension then it can't take it. If you have a smallish room then i would say you'd get enough bass end from a decent pair of nearfield monitors and that a sub bass will just add confusion to the recipe. If you have a bigger room it might be OK, but then you need some bass traps to stop any standing waves etc.
i don't know your system, but i would be a bit sceptical about letting my computer adjust anything - it can adjust the speakers, but it may be your room that needs adjusting.
zangsta
Post by zangsta »
Mr Arkadin wrote: i don't know your system, but i would be a bit sceptical about letting my computer adjust anything - it can adjust the speakers, but it may be your room that needs adjusting.
I got curious what his was about, and checked it out.
May be something for me! Thank´s for bringing this to my attention.
At times, we have no choice, and then this seems like a workable solution;
Introducing the new JBL LSR4300 Studio Monitors featuring RMC™ Room Mode Correction, JBL's exclusive technology that automatically analyzes and corrects the response of each speaker in the room for absolute accuracy at the mix position. The first studio monitors with powerful network intelligence built into each speaker specifically designed to deliver an accurate mix in any room, the LSR4300's are the ultimate monitor for modern production studios. The LSR4300 models feature stunning JBL sound, provide accurate mixes in any workspace, and are priced well within the reach of any project studio. The first self aware monitoring system, they're the only choice for music, post, broadcast, Surround 5.1, and beyond.
Included accessory kit contains:
Calibration microphone
Remote control
LSR4300 Control Center Software
USB and network cables
Mr Arkadin
All very well and good blurb, but it can't correct for reflections or standing waves - speakers just can't do that - acoustic treatment in some form is always necessary.
yep.
no getting around bass traps and diffusers...
all the speaker software can do is correct for flat response.
