Mac Mini Cube, good for Apple logic mixing? Gary
Wired
Post by Wired »
Gary, would you recommend getting a cube for mixing in logic, ?
not if the mixes were plugin heavy and complicated, for that i'd use a G5 if i used a mac.......but i'm no expert. :)
No to the G5, the current imacs are a lot more suitable to modern Logic use imo on a budget. The mini cube is more suitable for use as a logic node than a host for the sequencer (imo again).
Valis is right - the current iMac is a much better bang for the buck
it's more powerful, less noisy, has an internal PSU
and looks just great if you are into Alu design :D
:) there you go. from the mac masters...
