LOOPlay_2008_ CONTEST!!! +MP3
MCCY
Post by MCCY »
This is an overworked version of my old looplay but with new settings for different ULLI latency modes in 44.1 Khz. Now the timing should be correct (maybe not perfect, when jamming 10min..)
have fun
Martin
EDIT:
- Now LOOPlay & LOOPlay MM both updated!
- selectable ULLI pre - adjustments for all 44.1 values
- manually settable ULLI correction (in the tuning window (rightclick device and open Tuning)
Known issues:
- O.K. someday I will smoothen the rec-button to 100% avoid any clicking, but I don't see a real problem with that.
CONTEST:
Bring up some demos of your instrument -playing with LOOPlay!!!!! The winner will be the first person to get the fully featured FluLiq device!!! Personally send with an autograph ;)
LOOPLAY.zip
New LOOPlay & LOOPlay MM
(924.13 KiB) Downloaded 542 times
Thanks Martin,
I will check it out soon.
I am sure it was more than mon or enhancements as usual. :wink:
JV
MCCY
Post by MCCY »
LOOPlay MM with its 8 delays is still in progress being updated to the ULLI-Problematic. I had a version running for some time, but invested not much energy & motivation. I think I will add a version with manual tweaking, so even 48 khz will be possible & maybe a kind person could experiment to get the "perfect" tweaking-values.
As far as I can see it's all about adding some samples something around ~ 1000 when using smaller Ulli rates & I bet it changes just the numbers when switching to 48khz.
Martin
Coolness,
What's the advantage of 48Khz?
Redbook recording maybe. :-?
MCCY
Post by MCCY »
Could be interesting for life - usage-converting-quality, but I wouldn't care about it.
