Windows 2000, Scope and Cubase VST
eric
Post by eric »
I am just switching over to Win2K as I have found it the most stable platform for many things. I was running a Pulsar I card with VST32 under Win98. It never really worked well, and I could not get GigaStudio to work at all!
The Motherboard is Gigabyte and has all the slots I require. The video card is also Gigabyte, not flash but adequate.
Can someone point me to the right drivers to use for both Cubase and Scope?
Are there any issues known about this combination?
Thanks in advance,
Eric.
the same win2k driver is for both xp and 2k.
xp is solid enough to work for a week without saving. i'd go xp, but do as you like.
MrV
Post by MrV »
Hi Eric ,
Good one ... yes , I've always found XP to be very stable . no experience of Win2000.
See you friday .
Cheers , Michael
kylie
Rank-o-phile
Post by kylie »
Win2000 and scope is fine, been using this combination for years.
no big experience with cubase, but SL3 is at least installed, and afair works together with scope (I only needed it for being able to open some projects from other people).
-greetings, markus-
eric
Win@k and Scope
Post by eric »
Thanks for all your replies.
I will try XP Pro now that SP3 is out.
Eric.
kylie
Rank-o-phile
Re: Win@k and Scope
Post by kylie »
eric wrote:I will try XP Pro now that SP3 is out.
XP SP3 is still RC2. the final version will be most probably released "in the first half of 2008"...
-greetings, markus-
besides, xp sp2 is stable enough for commercial work.
eric
Re: Windows 2000, Scope and Cubase VST
Post by eric »
Thanks for all the replies.
I have now moved over to XP.
All is fine.
Had to do some major reconfiguring of the studio but is now more efficient.
The Scope platform is great.
Eric.
Your mouse has moved. Windows must be restarted for these settings to take effect.
Eric Northwood - Data Recovery Specialist
MrV
Post by MrV »
Good move old chap . Regards , MV
