i have just discovered that if you load a device, for example the MINIMAX, you can midi-assign all the controllers to remote control the synth with your external midi contrl surface, save the device with a new name (minimax MIDI.mld) and, voilà!, when you load this device the midi controller are ready to go!
very useful!
now, i'd like to do the same with dynatube, but it has the problem that it desnt have the midi input!! so, how can bypass this??
moreover, i just noticed that the dynatube doesnt restore the presets because the "preset list" are not inserted into the "parameters" window (as the "first time use.doc" says to do for saving presets...
i think there are no exit to this bug, but maybe someone has an idea.... is sonic core aware of this bug!?!?!?!
thanks!
							saving a stock device with midi assignement!
- FrancisHarmany
- FrancisHarmany
- FrancisHarmany
I continue to have some problems with the midi, because it doesn't remember any settings.bosone wrote:you can set up a midi assignement and save it under the "MIDI" folder in the preset list.
later, you can recall the midi assignement by loading the appr. preset in the "MIDI" section of the preset list!
Is there someone who has succeeded in maintaining in memory and to recall a setting of all the controls without losing one of it?
In example I have problems with prodyssey because it doesn't remember the control of the VCA volume of the mixer.
I cannot create a "midized" Prodyssey and ProTone with SDK (as seen in this post) because it's registred to another card in another PC, away from SDK enviroment.
I want avoid to move the cards from a system to another risking to ruin the equilibrium of the overall studio setup.
The midi folder into preset panel could be the right solution but it seems not to work well!
Anyone? Any comment or solution?
Thanks in advance.
