What about this new granular synth?
sonicstrav
Post by sonicstrav »
Any info on this?
spacef
Post by spacef »
I found a nice spot that i like on the granular osc , when it does a kind of tubular FM. but at musikmess it is a bit difficult to judge with the background noise, i didn't try many presets neither. John Bowen had a tour by the developper himself , so it was a more educated test.
nb: i say it is light, but i think i remember now i was tetsing in Xcite. I also tested it in the Scope v 5.0 and Vista, it seemed as light to me but didn't check dsp at all in fact). The preset list was the same (i remember having told two viitors to "press P" to change presets ( :lol: ).
petal
Post by petal »
Sounds like you were "under the influence" ;)
Shroomz~>
Post by Shroomz~> »
Passing on some good vibes from somewhere not as exotic as Vienna. :D
My info is on a purely NTN basis. :lol:
Marvin
Re: What about this new granular synth?
Post by Marvin »
strav100 wrote:Any info on this?
If I remeber right it is called gizzmo. Ralf told me it needs a certain DSP amount. But with the new hardware >>> no prob! :-) Since DSP power is now virtually unlimited the gate is open for very powerful algos to follow.
julian
Post by julian »
Hello everybody!
I'm the one responsible for the Gizzmo :D
here are some specs:
Sound Generators
2 granular sampling oscillators (granular parameters: playback speed, sample length, grain density, grainsize, position)
1 bandpass filtered noise generator
Envelope
2 envelope generators with variable slopes.
LFO
2 multi wave LFOs per voice
7 waveforms ( sine, rec, saw up/down, tri, random, smooth random)
adjustable phase, delay, clock sync and freerun/retrigger mode.
Both LFOs are audio rate capable and can be used to create rich FM-sounds with the provided keytracking feature.
Filter
LP / HP
Formant filter
Comb Filter
FX
Ringmodulator
Sample rate reducer
Distortion
Sequencer
1 Note Sequencer - classical analog style sequencer with pitch, volume and gate.
2 Modulation Sequencers per voice with different playmodes (loop, key trigger, EG Mode) it can be used as 16-stage-multi-EG with attack, loop, and release phase
x/y – Pad
free routable to 34 targets
Mod Matrix
8 slots
1 source and 2 Target with adjustable amount per slot
15 modulation sources
35 modulation targets
all modulation paths are sync signals, so you can also use the OSCs as mod source and make nice FM/AM sounds. :D
FX Routing
Here the position of the redux/distortion, comb and formant module in the signal path can be changed.
Possible locations are before and after the LP/HP filter, as well as at the end of the signal path after the amplifier.
Since I'm on easter holiday at the moment, I haven't got any soundsamples at hand. but they will follow ;)
have a nice day,
Julian
I'm gonna have a nice year w/ this !!!
Could you post any pics since you are the creator?
Any sound demos?
BTW, a very nice first post,......welcome to the Z
Thanks, this looks very enticing. :D
decimator
Post by decimator »
Hello ! :)
Can the playback speed be negative ? ( reverse )
julian
Post by julian »
sure :)
it can be adjusted from -2 to 2.
there's an additional speed boost option that expands the range from -10 to 10.
you can even modulate the playback speed gradually from positive to negative.
so long,
jul
hifiboom
Post by hifiboom »
great....
the hidden man from SC. :)
Were you the chick sitting down and snacking in the video ? :lol:
decimator
Post by decimator »
That should rock then, just great ! :D
Shroomz~>
Post by Shroomz~> »
Hi Jul,
Gizzmo, sounds very cool.
Looking forward to hearing it. :)
welcom Julian, quite a first post :-D
great to have you around.
it looks like SC makes kind a statement with Gizzmo, as it's beyond the classic substractive aproach :-)
Very smart, it also looks like a winner having read your description :-
borg
Post by borg »
I'm very interested to give it a go... A demo video would be great :D
andy
the lunatics are in the hall
bosone
Post by bosone »
"sampling oscillator" means that we could load our samples?
johnbowen
Post by johnbowen »
Yes, you load whatever samples you want, like usual Scope process.
-john b.
bill3107
Post by bill3107 »
Bienvenido Julian ! And thanks for the details !!! :wink:
maky325
Post by maky325 »
And now some sound preview :)
julian
Post by julian »
Hello everybody,
I finally made it and recorded some random sounds from the Gizzmo Synth.
Nothing special, just some freehand sounds I recorded on the fly.
http://www.chipmusik.de/gizzzzmo.mp3
First you hear the timestretching abilities. The flute sample is triggered and I'm tweaking the speed parameter in realtime.
afterwards I play some notes and the speed is set to zero. I'm tweaking the position parameter to 'scroll' through the flute sample.
after that, you hear some random presets. The Vocal like sequence is played with the sequencers. No formant filter is used. It's a vocal sample containing a-e-i-o-u and the modulation sequencer is used to vary the position in the sample.
No external FX were used. Audio directly recorded from the gizzmo audio out.
I hope you like it!
so long,
julian
