Its a midi gate controller for beefing up certain hits, trance gate, ducking, glitching and much more.
a stereo stream is fed to the device as well as midi, the audio is split to the 6 independent processors, each of which is controlled by a different note and velocity.
the timing and placement of each gate is controlled from your sequencer or keyboard.
you can use any stereo insert in each slot.
it has a special mode for delays or reverb where the sound is captured at the beginning of the gate period, then cut off so you can only hear the effect until the gate period ends.
I was hoping to release it tonight, but i have some things to fix before the beta is ready.
in case anyone is interested the panel is rendered in 3dsmax with Vray 1.5
with a bit of luck ill change the knobs as well.
Teaser MGC-6
Teaser MGC-6
- MGC_6.JPG (62.2 KiB) Viewed 1748 times
part of the idea came from your filterbox. as well as Dblue glitch and the little trance gate thingys in vanguard etc. and something i will work on later (when i get a better motherboard that doesnt crash when i load too many delays,)
a virus atomizer type thing
I have never been too happy with scope onboard (anything thats supposed to keep sync to MIDI) i hope soniccore will make sync MIDI stuff.
- Mr Arkadin
