saving midi cc's in project
Jah Servant
I'm having problems getting midi cc's to save within a project. I always have to load the midi controller preset for any devices I have made, it's a small thing but I'd like it to save in the project. thanks for any help
This is strange question because if it saves in presets, then it should save in projects too ... no ?
There is an absolute rule i discovered though :
- don't connect several graphics together. it bugs midi cc functions.
Also try to see if connecting a controller pad between the pot/fader changes something (eventhough, if your CC work fine in midi-cc-presets, there should no need for this).
that's it i think.
that's it i think.
Hey Mehdi, did FrancisHarmany contact you about this earlier today?
I've had feedback reports of this problem, but I think the reports must refer to the fact that my devices don't recall midi CC assignments automatically without using the midi-CC-presets (which is something that stock CW effects can do - IE you don't need to save a midi controller preset for them to recall the CC assignments). My devices DO seem to work fine here with midi-CC-presets though (whether inserted or standalone).
Another issue I noticed when comparing my insert FX to stock CW ones is that mine don't pass the midi CC data out of the inserted effect & on to it's host's midi output (whether I put midi I/Os on the insert effect or not).
Jah Servant
it's strange because when you reload the project and open the midi assignment it shows the controls assigned, but when you then open the controller settings it isn't there.
I tried connecting my controls directly to pads instead of to the other controls and that doesn't seem to help either. I unchecked and rechecked all the boxes too but it didn't make any difference.
