Hi! !
I need your help !!
I try to understand scope philosophy !!!
I'me reeding the manual !! and first ,
I don't know what is the différence between Asio1 or Asio 2 beside Direct monitoring / and which one should i choose /
Too, is it possible to sequence scope's synths from cubase's midi sequencer ... ?
thx
help to understand Scope
months ago i began a simple scope tutorial, never finished.
there are just the first steps...
maybe one day i will find the time to go on!
http://www.alchemystudio.it/tutorial/cr ... ial_en.htm
Neil B
Neil B
Well Asio 2 is the one I use with Cubase and when you select your audio output in Cubase, select Asio Scope.
I'm not an expert but it may depend on your Cubase & Scope versions.
Let us all know what you're using and you'll get a more explanatory answer from someone..
By the way - welcome to Planet Z
It will work with any asio driver given that:
- you put in the project the same type of asio source and asio dest modules (both source and dest are needed to proper function)
end.
differences:
asio1 was created before asio2 so it is somewhat lighter including less features.
asio2 provides support for "direct monitoring" and I don't know what else, probably they're stabler?
that's all I know, people report to use both without any big problem.
next, it would be important to choose the ones with your favorite sample size: 16, 24, 32bit. If I remember well ASIO2 dest module is the same for every sample size (people correct me if I'm wrong!)
cheers
Fede
end.
differences:
cheers
Fede
Re: help to understand Scope
2 is better than 1. im still on 44.1kz/16bit
btw what was the 96khz conclusion?
a. after convert for cd it wont help.
b. it helps.. go for it
