Mark
A little tip ;)
A little tip ;)
Not sure if this has been covered before, but if you're having problems viewing Insert Effect menus, using the Mod shells, using PresetLists etc within the sdk, then take a look at your Scope cset.ini file. For those who haven't looked at it before, It can be found under C:\Scope\App\Bin. You can view it with a text editor like Notepad. The bit we're interested in here is the StaticPath section. If you copy the relevant entries from this section into the cset.ini file in your sdk install, you'll then be able to do quite a few things that you previously couldn't.
Mark
Mark
Re: A little tip ;)
Many THANKS Mark !!!
Nice one.
CheerZ
Nice one.
CheerZ
