my new studio pc
arted
my new studio pc
Post by arted »
my first post here is a big thank you.
i was advised to get the asus p5k for a soniccore/scope fusion set up.
after finding more post about problems with that setup,
i decided to jump the wagon and try it with the new intel board as some users posted that the asus dp35dp works perfect
so here my specs...
System Information
Time of this report: 12/5/2008, 03:12:59
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
Language: German (Regional Setting: German)
System Manufacturer: INTEL
System Model: DP45SG
BIOS: BIOS Date: 08/15/08 15:04:09 Ver: 08.00.10
Processor: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2 CPUs)
Memory: 3324MB DDR3 RAM
Page File: 583MB used, 4623MB available
DirectX Version: DirectX 9.0c (4.09.0000.0904)
Display Devices
Card name: NVIDIA GeForce 9800 GT
Manufacturer: NVIDIA
Chip type: GeForce 9800 GT
DAC type: Integrated RAMDAC
Display Memory: 512.0 MB
Current Mode: 1280 x 1024 (32 bit) (85Hz)
Monitor: SyncMaster 1100MB
Disk & DVD/CD-ROM Drives
Model: WDC WD740ADFD-00NLR5 (raptor with 4,7ms)
Model: ST3250310NS (ES 24h drive)
i call it my 'männerlaptop'
build in a 19" servercase i can fit it in a roadcase :)
it uses a 3-slot hotswap SATA changer with one slot still empty
and DVD-writer which was very close as there is only 2-3mm from the back of the dvd to the motherboard
and its power supply which is a 850W targan.
currently i experience none of all the troubles before
with installation and set up
and the pulsar runs perfectly.
arted
Re: my new studio pc
Post by arted »
hmmm
im a total noob here..
i think you mean masterverb test?
how exactly should i do that?
okantah
Post by okantah »
arted have you test the STS samplers ?
cheers
gustav
Post by gustav »
okantah wrote:arted have you test the STS samplers ?
cheers
Hi - I'm looking for a new setup and it would be very interesting to know if you have any problemes by using sts ...
Bye - Gustav
_______________________________________
our music at http://algufr.bandcamp.com
and at http://alg95.bandcamp.com
more music at http://hurpasard.free.fr/index_en.html
okantah
Post by okantah »
HI gustav,i always GET too late to reply your post directed at me,sorry for many time.
The asus p5 wd2-e premium is very tough mobo but once it;s installed good it rock very high to none,
your answer is yes...
STS are the only samplers iam using.if you have not succeseded yet ??? that's seems too long till now.
please try the below installations setting,other than that there might be problems with your mobo.pls pay attention on the (ACPI support) (ACPI\APIC) ( PnP set )
1 Reset bios to default.
2 ACPI support..yes
3 ACPI\APIC.... enable
4 PnP set to yes.
5 save bios to new settings,reboot,
6 when windows start load drivers,press & hold F5.choose either
multiprocessor Or standard pc,any of these setting must work if not try
the other.press enter to your selected choice,windows will continue
loading restart within 30 seconds,enter in the bios again,this time very
important:
7 ACPI support..yes
8 ACPI\APIC.... disable
9 PnP set to no.
save bios to new settings,reboot,continue windows installation,
much success.
gustav
Post by gustav »
hey - its nice to hear from you - but for this mb its toolate for me
I changed for a new setup with intel mb dp35dp
I had some issues in the beginning ( http://forums.planetz.com/viewtopic.php?f=1&t=26804 )
there are some strange things happening sometimes but I had no time to have a closer look at that.
Bye - Gustav
okantah
Post by okantah »
good to hear that all working fine.
for mine only thing disable is onboard audio.the rest all enable internet,usb,ect 24 hours on no problem.
anyway have fun
Okantah
arted
Post by arted »
stardust wrote:Basically you open an empty project and add as many masterverbs until either DSP limit or PCI limit is reached.
This usually gives a good hint about the overall PCI performance of the system
ohh late response with my normal startup ..just mixer and drivers i can load 9 masterverbs
I got 12 masterverbs on my PK5E
Results here :
http://forums.planetz.com/viewtopic.php ... masterverb
View ScopeRise latest issue at www.hitfoundry.com
