V5 install problem- then more problems... :/
eliam
Post by eliam »
Well, well, in my eagerness to try the new plugins I took the plunge and tried to install scope 5... A dumb move it seems...
When feeding the installer with my new keyfile it just refused the new keys, saying "key import failed"...
hmmm
So, I tried to revert back to the old drivers, uninstalled V5 and all, and 1 of my 6 dsp boards won't be satisfied with the good ol 4.5 driver and requests a scPci wdm driver, which is associated to scope 5... And SFP won't work without this card, not sure why...
I physically removed the card, rebooted, turned-off, put the card back, rebooted, same thing... It won't install. So I'm here between 2 chairs, with no access to my scope cards... That'S frustrating.
I wrote SC to tell them about the problem, I hope to have a fix ASAP...
Now if anyone has an idea on how I can get it working the old way, please let me know...
fidox
Re: V5 install problem- then more problems... :/
Post by fidox »
i would try :
-un-install scope 5 and remove cards from device manager, reboot,
install back 4.5 and manually install cards -driver back in device manager,
did you send scope.rgy, where you had all keys installed ?
first i send wrong allkeys.sfk and a lot of devices where missing there, cause
a lot were installed manually after last allkeys.sfk was created,
so all information with keys for all plugins was in scope.rgy
just a guess.....
matej
Emilio Biagini
Post by Emilio Biagini »
A message appeared telling me that "the hardware is type 16, needed a software update", or something similar (??????????)
Can somebady give advice?
Emilio :(
eliam
Post by eliam »
Thanks for the input, yes I tried all this, but when I try to re-install the board it wants a wdm driver from the V5 location (which has been deleted) and the installation fails...
Fluxpod
Post by Fluxpod »
Emilio Biagini wrote:A message appeared telling me that "the hardware is type 16, needed a software update", or something similar (??????????)
Emilio :(
Read here.http://forums.planetz.com/viewtopic.php?f=1&t=27566
fidox
Post by fidox »
eliam wrote:I try to re-install the board it wants a wdm driver from the V5 location (which has been deleted) and the installation fails...
yes, but what if you try to re-locate (browse) to sfp 4.5/driver folder and add from there ?
eliam
Post by eliam »
Actually this happens after I've specified the 4.5 driver's location, while the drivers are being installed.
eliam
Post by eliam »
... and the old driver will not work at this point...
Emilio Biagini
:x
DEAR FRINDS,
PLEASE STOP !!!!
Is ever possible that to update a stupid software we should be COMPUTERS ENGINEERS?????????????
After 2 years waiting is clear to me that this software is still IMMATURE
f..ck!!!!
EB
Fluxpod
Post by Fluxpod »
Have you read THIS http://forums.planetz.com/viewtopic.php?f=1&t=27566 ? Its really not rocket science. :D
siriusbliss
Post by siriusbliss »
I recommend turning OFF 4.5 before installation of V5.
Then rename the 4.5 folder to something else (i.e. Scope4.5_backup)
I also highly recommend burning an image of your system prior to installation.
Immanuel
Post by Immanuel »
Emilio Biagini wrote::x
DEAR FRINDS,
PLEASE STOP !!!!
f..ck!!!!
EB
It is called a release candidate for a reason :roll:
You are betatesting and expecting a finnished software? That is not very clever.
eliam
Post by eliam »
I communicated with SC who sent me 2 more "activation keys" (for a total of 3), all of which were rejected by the installer...
I managed to revert to 4.5 thanks to my scope folder backup.
Am I the only one having this ("import of key file failed!") problem?
next to nothing
Post by next to nothing »
You aren't trying to install v5 to scope 4.5 folder by any chance?
eliam
Post by eliam »
no, and I don't plan to try anything until the official V5 release... I need to work with my system.
